Size: 5.5 x 12
Design Span (L): 19.75 ft.
Clear Span: 19.25 ft.
Total Span: 20.25 ft.
Live Load: 4200 lbs
Dead Load: 2000 lbs
Selfweight: 305.6 lbs
Dist. Selfweight: 15.47 plf
Total Weight: 313.3 lbs
CV Volume Factor 0.999b - - - - -
Beam Design Myles 17404 Pavillion
8/15/2023 1
8/15/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [66.00 x (237.00 + 6)] x (12 in./ft.)3 = 9.28 ft3
Volumespan = N[A x L] = 1 x [66.00 x 237.00] x (12 in./ft.)3 = 9.05 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.28 = 313.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.05 = 305.6 lbs
4200 lbs
2000 lbs
  ws = 15.47 plf
19.75 ft.
19.25 ft.
20.25 ft.
3256.67 lbs
3256.67 lbs
8/15/2023 3
CV = = 0.999
CV = 0.999 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.999) = 2757.4 psi
fb = = 2851.5 psi
 fb = 2851.5 psi > Fbx' = 2757.4 psi  (CSI = 1.03)   ➜  NG
8/15/2023 4
fv* = = 73.58 psi
 fv* = 73.58 psi < Fvx' = 304.75 psi  (CSI = 0.24)   ➜  OK
fv = = 73.93 psi
 fv = 73.93 psi < Fvx' = 304.75 psi  (CSI = 0.24)   ➜  OK
8/15/2023 5
ΔLL =   =   = 0.82 in.
(L/d)LL = 237.00 / 0.82 = 290
 ΔLL = 0.82 in = L/290 < L/240   ➜  OK
ΔTL =   =   = 1.24 in.
(L/d)TL = 237.00 / 1.24 = 191
 ΔTL = 1.24 in = L/191 < L/180   ➜  OK
fc⊥ = = 98.7 psi
 fc⊥ = 98.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.15)   ➜  OK
8/15/2023 6
