Grade: 24F-V3 1.8E SP/SP
Size: 2.5 x 11
Design Span (L): 23.71 ft.
Clear Span: 23.42 ft.
Total Span: 24.00 ft.
Bearing (lb): 3.5 in.
Quantity (N): 4
Live Load: 220 plf
Dead Load: 55 plf
Selfweight: 668.1 lbs
Dist. Selfweight: 28.18 plf
Total Weight: 676.3 lbs
Beam Design 2023A324
8/9/2023 1
b = 2.500 in.
d = 11.000 in.
A = 2.500 x 11.000 = 27.50 in.2
Sx = (2.500)(11.000)2/6 = 50.42 in.3
Sy = (2.500)2(11.000)/6 = 11.46 in.3
Ix = (2.500)(11.000)3/12 = 277.29 in.4
Iy = (2.500)3(11.000)/12 = 14.32 in.4
8/9/2023 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 4 x [27.50 x (284.50 + 3.5)] x (12 in./ft.)3 = 18.33 ft3
Volumespan = N[A x L] = 4 x [27.50 x 284.50] x (12 in./ft.)3 = 18.11 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 18.33 = 676.3 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 18.11 = 668.1 lbs
Distributed Self Weight (ws) = = 28.18 plf
220 plf
55 plf
  ws = 28.18 plf
23.71 ft.
23.42 ft.
24.00 ft.
3638.10 lbs
3638.10 lbs
8/9/2023 3
fb = = 1267.5 psi
 fb = 1267.5 psi < Fbx' = 2760.0 psi  (CSI = 0.46)   ➜  OK
8/9/2023 4
fv* = = 45.22 psi
 fv* = 45.22 psi < Fvx' = 345.00 psi  (CSI = 0.13)   ➜  OK
fv = = 49.01 psi
 fv = 49.01 psi < Fvx' = 345.00 psi  (CSI = 0.14)   ➜  OK
8/9/2023 5
ΔLL = = 0.78 in.
(L/d)LL = 284.50 / 0.78 = 363
 ΔLL = 0.78 in = L/363 < L/360   ➜  OK
ΔTL = = 1.08 in.
(L/d)TL = 284.50 / 1.08 = 264
 ΔTL = 1.08 in = L/264 < L/240   ➜  OK
Ab = b x lb = 2.5 x 3.5 = 8.75 in2
fc⊥ = = 103.9 psi
 fc⊥ = 103.9 psi < Fc⊥x' = 740.00 psi  (CSI = 0.14)   ➜  OK
8/9/2023 6
