Grade: SPF Stud
Design Span (L): 6.38 ft.
Clear Span: 6.25 ft.
Total Span: 6.50 ft.
Bearing (lb): 1.5 in.
Live Load: 18.75 plf
Dead Load: 50 plf
Selfweight: 10.6 lbs
Dist. Selfweight: 1.67 plf
Total Weight: 10.8 lbs
Beam Design 2023A323
8/6/2023 1
SPF Stud 675 350 135 425 725 1200000 440000 0.42
8/6/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (76.50 + 1.5)] x (12 in./ft.)3 = 0.37 ft3
Volumespan = N[A x L] = 1 x [8.25 x 76.50] x (12 in./ft.)3 = 0.37 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.37 = 10.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.37 = 10.6 lbs
18.75 plf
50 plf
ws = 1.67 plf
6.38 ft.
6.25 ft.
6.50 ft.
228.86 lbs
228.86 lbs
8/6/2023 3
Fbx' = (675)(1.00)(1)(1)(1)(1)(1)(1) = 675.0 psi
fb = = 567.6 psi
 fb = 567.6 psi < Fbx' = 675.0 psi  (CSI = 0.84)   ➜  OK
8/6/2023 4
fv* = = 34.94 psi
 fv* = 34.94 psi < Fvx' = 135.00 psi  (CSI = 0.26)   ➜  OK
fv = = 40.81 psi
 fv = 40.81 psi < Fvx' = 135.00 psi  (CSI = 0.30)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1200000(1)(1)(1) = 1200000 psi
8/6/2023 5
ΔLL = = 0.03 in.
(L/d)LL = 76.50 / 0.03 = 2740
 ΔLL = 0.03 in = L/2740 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 76.50 / 0.10 = 730
 ΔTL = 0.10 in = L/730 < L/240   ➜  OK
fc⊥ = = 101.7 psi
 fc⊥ = 101.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.24)   ➜  OK
8/6/2023 6
