Grade: SP DSS
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 40 lbs
Dead Load: 5 lbs
Selfweight: 44.4 lbs
Dist. Selfweight: 2.82 plf
Total Weight: 45.1 lbs
Beam Design 2023A322
8/5/2023 1
SP DSS 2200 1550 175 660 1850 1900000 690000 0.55
8/5/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (189.00 + 3)] x (12 in./ft.)3 = 1.21 ft3
Volumespan = N[A x L] = 1 x [10.88 x 189.00] x (12 in./ft.)3 = 1.19 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.21 = 45.1 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.19 = 44.4 lbs
Distributed Self Weight (ws) = = 2.82 plf
40 lbs
5 lbs
ws = 2.82 plf
15.75 ft.
15.50 ft.
45.05 lbs
45.05 lbs
8/5/2023 3
Fbx' = (2200)(1.15)(1)(1)(1)(1)(1)(1) = 2530.0 psi
fb = = 241.6 psi
 fb = 241.6 psi < Fbx' = 2530.0 psi  (CSI = 0.10)   ➜  OK
8/5/2023 4
fv* = = 5.93 psi
 fv* = 5.93 psi < Fvx' = 201.25 psi  (CSI = 0.03)   ➜  OK
fv = = 6.17 psi
 fv = 6.17 psi < Fvx' = 201.25 psi  (CSI = 0.03)   ➜  OK
8/5/2023 5
ΔLL =   =   = 0.06 in.
(L/d)LL = 189.00 / 0.06 = 3040
 ΔLL = 0.06 in = L/3040 < L/360   ➜  OK
ΔTL =   =   = 0.11 in.
(L/d)TL = 189.00 / 0.11 = 1672
 ΔTL = 0.11 in = L/1672 < L/240   ➜  OK
fc⊥ = = 10.0 psi
 fc⊥ = 10.0 psi < Fc⊥x' = 660.00 psi  (CSI = 0.02)   ➜  OK
8/5/2023 6
