Grade: DF SS
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Quantity (N): 4
Live Load: 346 plf
Dead Load: 139 plf
Selfweight: 260.5 lbs
Dist. Selfweight: 16.03 plf
Total Weight: 264.5 lbs
Beam Design 2023A321
8/3/2023 1
8/3/2023 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (195.00 + 3)] x (12 in./ft.)3 = 7.73 ft3
Volumespan = N[A x L] = 4 x [16.88 x 195.00] x (12 in./ft.)3 = 7.62 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.73 = 264.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 7.62 = 260.5 lbs
346 plf
139 plf
ws = 16.03 plf
16.25 ft.
16.50 ft.
4133.52 lbs
4133.52 lbs
8/3/2023 3
Fbx' = (1500)(1.15)(1)(1)(1)(1)(1)(1) = 1725.0 psi
fb = = 1568.0 psi
 fb = 1568.0 psi < Fbx' = 1725.0 psi  (CSI = 0.91)   ➜  OK
8/3/2023 4
fv* = = 80.03 psi
 fv* = 80.03 psi < Fvx' = 207.00 psi  (CSI = 0.39)   ➜  OK
fv = = 90.46 psi
 fv = 90.46 psi < Fvx' = 207.00 psi  (CSI = 0.44)   ➜  OK
8/3/2023 5
ΔLL = = 0.40 in.
(L/d)LL = 195.00 / 0.40 = 486
 ΔLL = 0.40 in = L/486 < L/360   ➜  OK
ΔTL = = 0.58 in.
(L/d)TL = 195.00 / 0.58 = 336
 ΔTL = 0.58 in = L/336 < L/240   ➜  OK
fc⊥ = = 229.6 psi
 fc⊥ = 229.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.37)   ➜  OK
8/3/2023 6
