Grade: SP DSS
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 300 plf
Selfweight: 26.0 lbs
Dist. Selfweight: 4.52 plf
Total Weight: 27.1 lbs
CL Beam Stability Factor 0.955 - - - - -
Beam Design 2023A32
2/19/2023 1
Beam Design 2023A32
2/19/2023 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (69.00 + 3)] x (12 in./ft.)3 = 0.70 ft3
Volumespan = N[A x L] = 1 x [16.88 x 69.00] x (12 in./ft.)3 = 0.67 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.70 = 27.1 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.67 = 26.0 lbs
Distributed Self Weight (ws) = = 4.52 plf
300 plf
ws = 4.52 plf
5.75 ft.
5.50 ft.
1138.56 lbs
1138.56 lbs
Beam Design 2023A32
2/19/2023 3
lu/d = = 2.13
Rb = = 15.72
 Rb = 15.72 < 50   ➜  OK
Beam Design 2023A32
2/19/2023 4
Eminy' = Eminy(CM)(Ct)(Ci) = 690000(0.9)(1)(1) = 621000 psi
FbE = = 3014.56 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1800)(1.00)(0.85)(1)(1)(1)(1) = 1530.00 psi
CL =   = 0.955
Fbx' = (1800)(1.00)(0.85)(1)(0.955)(1)(1)(1) = 1461.3 psi
fb = = 594.9 psi
 fb = 594.9 psi < Fbx' = 1461.3 psi  (CSI = 0.41)   ➜  OK
fv* = = 65.36 psi
 fv* = 65.36 psi < Fvx' = 169.75 psi  (CSI = 0.39)   ➜  OK
fv = = 96.99 psi
 fv = 96.99 psi < Fvx' = 169.75 psi  (CSI = 0.57)   ➜  OK
Beam Design 2023A32
2/19/2023 5
ΔLL = = 0.02 in.
(L/d)LL = 69.00 / 0.02 = 2846
 ΔLL = 0.02 in = L/2846 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 69.00 / 0.03 = 2250
 ΔTL = 0.03 in = L/2250 < L/240   ➜  OK
Fc⊥x' = (660)(0.67)(1)(1) = 442.20 psi
fc⊥ = = 253.0 psi
 fc⊥ = 253.0 psi < Fc⊥x' = 442.20 psi  (CSI = 0.57)   ➜  OK
Beam Design 2023A32
2/19/2023 6
