Beam Design - Melissa Huet Basement beam
Grade: SPF SS
Quantity (N): 5
Live Load: 640 plf
Dead Load: 240 plf
Selfweight: 200.3 lbs
Dist. Selfweight: 17.05 plf
Total Weight: 204.6 lbs
Notes: Nelson Plan HR1319
Beam Design Ryan Bailey PO Box 16, Station A, Calgary, AB 220728
7/28/2023 1
7/28/2023 2
Volumetotal = N[A x (L + lb)] = 5 x [16.88 x (141.00 + 3)] x (12 in./ft.)3 = 7.03 ft3
Volumespan = N[A x L] = 5 x [16.88 x 141.00] x (12 in./ft.)3 = 6.88 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 7.03 = 204.6 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 6.88 = 200.3 lbs
Distributed Self Weight (ws) = = 17.05 plf
640 plf
240 plf
ws = 17.05 plf
5382.30 lbs
5382.30 lbs
7/28/2023 3
lu = Unbraced Length = 11.750 ft.
lu/d = = 12.53
le = 1.63lu + 3d = 1.63(141.0) + 3(11.25) = 263.58 in. = 21.97 ft.  (NDS Table 3.3.3)
Rb = = 7.26
 Rb = 7.26 < 50   ➜  OK
7/28/2023 4
FbE = = 12519.92 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1250)(1.00)(1)(1)(1)(1)(1) = 1250.00 psi
CL =   = 0.995
Fbx' = (1250)(1.00)(1)(1)(0.995)(1)(1)(1) = 1243.1 psi
fb = = 1174.3 psi
 fb = 1174.3 psi < Fbx' = 1243.1 psi  (CSI = 0.94)   ➜  OK
fv* = = 78.74 psi
 fv* = 78.74 psi < Fvx' = 135.00 psi  (CSI = 0.58)   ➜  OK
fv = = 93.69 psi
 fv = 93.69 psi < Fvx' = 135.00 psi  (CSI = 0.69)   ➜  OK
7/28/2023 5
ΔLL = = 0.21 in.
(L/d)LL = 141.00 / 0.21 = 686
 ΔLL = 0.21 in = L/686 < L/360   ➜  OK
ΔTL = = 0.29 in.
(L/d)TL = 141.00 / 0.29 = 489
 ΔTL = 0.29 in = L/489 < L/240   ➜  OK
fc⊥ = = 239.2 psi
 fc⊥ = 239.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.56)   ➜  OK
7/28/2023 6
