Beam Design - Melissa Hunt Basement beam
Grade: SPF SS
Quantity (N): 4
Live Load: 640 plf
Dead Load: 240 plf
Selfweight: 160.3 lbs
Dist. Selfweight: 13.64 plf
Total Weight: 163.7 lbs
Notes: Nelson Plan HR1319
Beam Design Ryan Bailey PO Box 16, Station A, Calgary, AB 220728
7/28/2023 1
7/28/2023 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (141.00 + 3)] x (12 in./ft.)3 = 5.63 ft3
Volumespan = N[A x L] = 4 x [16.88 x 141.00] x (12 in./ft.)3 = 5.51 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 5.63 = 163.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 5.51 = 160.3 lbs
Distributed Self Weight (ws) = = 13.64 plf
640 plf
240 plf
ws = 13.64 plf
5361.84 lbs
5361.84 lbs
7/28/2023 3
lu = Unbraced Length = 11.750 ft.
lu/d = = 12.53
le = 1.63lu + 3d = 1.63(141.0) + 3(11.25) = 263.58 in. = 21.97 ft.  (NDS Table 3.3.3)
Rb = = 9.08
 Rb = 9.08 < 50   ➜  OK
7/28/2023 4
FbE = = 8012.75 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1250)(1.00)(1)(1)(1)(1)(1) = 1250.00 psi
CL =   = 0.991
Fbx' = (1250)(1.00)(1)(1)(0.991)(1)(1)(1) = 1238.7 psi
fb = = 1462.3 psi
 fb = 1462.3 psi > Fbx' = 1238.7 psi  (CSI = 1.18)   ➜  NG
fv* = = 98.05 psi
 fv* = 98.05 psi < Fvx' = 135.00 psi  (CSI = 0.73)   ➜  OK
fv = = 116.67 psi
 fv = 116.67 psi < Fvx' = 135.00 psi  (CSI = 0.86)   ➜  OK
7/28/2023 5
ΔLL = = 0.26 in.
(L/d)LL = 141.00 / 0.26 = 549
 ΔLL = 0.26 in = L/549 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 141.00 / 0.36 = 393
 ΔTL = 0.36 in = L/393 < L/240   ➜  OK
fc⊥ = = 297.9 psi
 fc⊥ = 297.9 psi < Fc⊥x' = 425.00 psi  (CSI = 0.70)   ➜  OK
7/28/2023 6
