Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Selfweight: 99.2 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 102.2 lbs
Beam Design 2450
7/25/2023 1
Beam Design 2450
7/25/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (99.00 + 3)] x (12 in./ft.)3 = 2.99 ft3
Volumespan = N[A x L] = 3 x [16.88 x 99.00] x (12 in./ft.)3 = 2.90 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.99 = 102.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.90 = 99.2 lbs
ws = 12.02 plf
8.25 ft.
8.50 ft.
794.85 lbs
794.85 lbs
Beam Design 2450
7/25/2023 3
fb = = 201.2 psi
 fb = 201.2 psi < Fbx' = 1035.0 psi  (CSI = 0.19)   ➜  OK
Beam Design 2450
7/25/2023 4
fv* = = 17.66 psi
 fv* = 17.66 psi < Fvx' = 207.00 psi  (CSI = 0.09)   ➜  OK
fv = = 22.86 psi
 fv = 22.86 psi < Fvx' = 207.00 psi  (CSI = 0.11)   ➜  OK
Beam Design 2450
7/25/2023 5
ΔLL = = 0.01 in.
(L/d)LL = 99.00 / 0.01 = 8114
 ΔLL = 0.01 in = L/8114 < L/360   ➜  OK
ΔTL = = 0.02 in.
(L/d)TL = 99.00 / 0.02 = 4339
 ΔTL = 0.02 in = L/4339 < L/240   ➜  OK
fc⊥ = = 58.9 psi
 fc⊥ = 58.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.09)   ➜  OK
Beam Design 2450
7/25/2023 6
