Design Span (L): 6.00 ft.
Clear Span: 5.75 ft.
Total Span: 6.25 ft.
Live Load: 495 plf
Dead Load: 135 plf
Selfweight: 48.1 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 50.1 lbs
Incised Lumber: Yes
Beam Design 2023A311
7/23/2023 1
7/23/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (72.00 + 3)] x (12 in./ft.)3 = 1.46 ft3
Volumespan = N[A x L] = 2 x [16.88 x 72.00] x (12 in./ft.)3 = 1.41 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.46 = 50.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.41 = 48.1 lbs
495 plf
135 plf
ws = 8.02 plf
5.75 ft.
6.25 ft.
1993.80 lbs
1993.80 lbs
7/23/2023 3
Fbx' = (900)(1.15)(1)(1)(1)(1)(0.8)(1) = 828.0 psi
fb = = 544.4 psi
 fb = 544.4 psi < Fbx' = 828.0 psi  (CSI = 0.66)   ➜  OK
7/23/2023 4
Fvx' = (180)(1.15)(1)(1)(0.8) = 165.60 psi
fv* = = 58.48 psi
 fv* = 58.48 psi < Fvx' = 165.60 psi  (CSI = 0.35)   ➜  OK
fv = = 85.07 psi
 fv = 85.07 psi < Fvx' = 165.60 psi  (CSI = 0.51)   ➜  OK
7/23/2023 5
ΔLL = = 0.03 in.
(L/d)LL = 72.00 / 0.03 = 2699
 ΔLL = 0.03 in = L/2699 < L/180   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 72.00 / 0.03 = 2094
 ΔTL = 0.03 in = L/2094 < L/120   ➜  OK
fc⊥ = = 221.5 psi
 fc⊥ = 221.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.35)   ➜  OK
7/23/2023 6
