Beam Design - Rhea Residence
Size: 5.125 x 15
Design Span (L): 15.00 ft.
Clear Span: 14.50 ft.
Total Span: 15.50 ft.
Live Load: 320 plf
Dead Load: 320 plf
Selfweight: 270.4 lbs
Dist. Selfweight: 18.02 plf
Total Weight: 279.4 lbs
CL Beam Stability Factor 0.953 - - - - -
Beam Design 2023A310
7/23/2023 1
b = 5.125 in.
d = 15.000 in.
A = 5.125 x 15.000 = 76.88 in.2
Sx = (5.125)(15.000)2/6 = 192.19 in.3
Sy = (5.125)2(15.000)/6 = 65.66 in.3
Ix = (5.125)(15.000)3/12 = 1441.41 in.4
Iy = (5.125)3(15.000)/12 = 168.26 in.4
7/23/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [76.88 x (180.00 + 6)] x (12 in./ft.)3 = 8.27 ft3
Volumespan = N[A x L] = 1 x [76.88 x 180.00] x (12 in./ft.)3 = 8.01 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.27 = 279.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.01 = 270.4 lbs
Distributed Self Weight (ws) = = 18.02 plf
320 plf
320 plf
  ws = 18.02 plf
15.00 ft.
14.50 ft.
15.50 ft.
5099.68 lbs
5099.68 lbs
7/23/2023 3
lu = Unbraced Length = 15.000 ft.
lu/d = = 12.00
le = 1.63lu + 3d = 1.63(180.0) + 3(15) = 338.40 in. = 28.20 ft.  (NDS Table 3.3.3)
Rb = = 13.90
 Rb = 13.90 < 50   ➜  OK
7/23/2023 4
FbE = = 5277.96 psi
CL =   = 0.953
CL = 0.953 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.953) = 2629.5 psi
fb = = 1155.6 psi
 fb = 1155.6 psi < Fbx' = 2629.5 psi  (CSI = 0.44)   ➜  OK
fv* = = 80.25 psi
7/23/2023 5
 fv* = 80.25 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
fv = = 96.30 psi
 fv = 96.30 psi < Fvx' = 304.75 psi  (CSI = 0.32)   ➜  OK
ΔLL = = 0.14 in.
(L/d)LL = 180.00 / 0.14 = 1281
 ΔLL = 0.14 in = L/1281 < L/180   ➜  OK
ΔTL = = 0.29 in.
(L/d)TL = 180.00 / 0.29 = 623
 ΔTL = 0.29 in = L/623 < L/120   ➜  OK
7/23/2023 6
Ab = b x lb = 5.125 x 6 = 30.75 in2
fc⊥ = = 165.8 psi
 fc⊥ = 165.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.26)   ➜  OK
7/23/2023 7
