Species: Hem-Fir
Grade: HF No.2
Size: 4 x 6
Design Span (L): 3.50 ft.
Clear Span: 3.21 ft.
Total Span: 3.79 ft.
Bearing (lb): 3.5 in.
Live Load: 220 plf
Dead Load: 180 plf
Selfweight: 13.9 lbs
Dist. Selfweight: 3.98 plf
Total Weight: 15.1 lbs
Incised Lumber: Yes
Beam Design 2023A31
2/17/2023 1
G = 0.43
Beam Design 2023A31
2/17/2023 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (42.00 + 3.5)] x (12 in./ft.)3 = 0.51 ft3
Volumespan = N[A x L] = 1 x [19.25 x 42.00] x (12 in./ft.)3 = 0.47 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 0.51 = 15.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 0.47 = 13.9 lbs
Distributed Self Weight (ws) = = 3.98 plf
220 plf
180 plf
ws = 3.98 plf
3.50 ft.
3.21 ft.
3.79 ft.
765.87 lbs
765.87 lbs
Beam Design 2023A31
2/17/2023 3
Fbx' = (850)(1.15)(1)(1)(1)(1.3)(0.8)(1) = 1016.6 psi
fb = = 420.7 psi
 fb = 420.7 psi < Fbx' = 1016.6 psi  (CSI = 0.41)   ➜  OK
Beam Design 2023A31
2/17/2023 4
Fvx' = (150)(1.15)(1)(1)(0.8) = 138.00 psi
fv* = = 40.66 psi
 fv* = 40.66 psi < Fvx' = 138.00 psi  (CSI = 0.29)   ➜  OK
fv = = 55.09 psi
 fv = 55.09 psi < Fvx' = 138.00 psi  (CSI = 0.40)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(1)(1)(0.95) = 1235000 psi
Beam Design 2023A31
2/17/2023 5
ΔLL = = 0.01 in.
(L/d)LL = 42.00 / 0.01 = 3389
 ΔLL = 0.01 in = L/3389 < L/360   ➜  OK
ΔTL = = 0.02 in.
(L/d)TL = 42.00 / 0.02 = 1845
 ΔTL = 0.02 in = L/1845 < L/240   ➜  OK
fc⊥ = = 62.5 psi
 fc⊥ = 62.5 psi < Fc⊥x' = 405.00 psi  (CSI = 0.15)   ➜  OK
Beam Design 2023A31
2/17/2023 6
