Beam Design - Deck mid Span
Size: 5.5 x 12
Design Span (L): 15.25 ft.
Clear Span: 15.00 ft.
Total Span: 15.50 ft.
Live Load: 374 plf
Dead Load: 187 plf
Selfweight: 247.9 lbs
Dist. Selfweight: 16.26 plf
Total Weight: 252.0 lbs
Beam Design Turner
7/20/2023 1
Beam Design Turner
7/20/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [66.00 x (183.00 + 3)] x (12 in./ft.)3 = 7.10 ft3
Volumespan = N[A x L] = 1 x [66.00 x 183.00] x (12 in./ft.)3 = 6.99 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 7.10 = 252.0 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 6.99 = 247.9 lbs
Distributed Self Weight (ws) = = 16.26 plf
374 plf
187 plf
  ws = 16.26 plf
15.25 ft.
15.00 ft.
15.50 ft.
4473.73 lbs
4473.73 lbs
Beam Design Turner
7/20/2023 3
fb = = 1525.5 psi
 fb = 1525.5 psi < Fbx' = 2208.0 psi  (CSI = 0.69)   ➜  OK
Beam Design Turner
7/20/2023 4
fv* = = 86.92 psi
 fv* = 86.92 psi < Fvx' = 266.66 psi  (CSI = 0.33)   ➜  OK
fv = = 100.04 psi
 fv = 100.04 psi < Fvx' = 266.66 psi  (CSI = 0.38)   ➜  OK
Beam Design Turner
7/20/2023 5
ΔLL = = 0.38 in.
(L/d)LL = 183.00 / 0.38 = 477
 ΔLL = 0.38 in = L/477 < L/360   ➜  OK
ΔTL = = 0.59 in.
(L/d)TL = 183.00 / 0.59 = 309
 ΔTL = 0.59 in = L/309 < L/240   ➜  OK
fc⊥ = = 271.1 psi
 fc⊥ = 271.1 psi < Fc⊥x' = 344.50 psi  (CSI = 0.79)   ➜  OK
Beam Design Turner
7/20/2023 6
