Design Span (L): 20.25 ft.
Clear Span: 20.00 ft.
Total Span: 20.50 ft.
Live Load: 0 lbs
Dead Load: 150 lbs
Selfweight: 52.3 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 53.0 lbs
Beam Design 2023A306
7/20/2023 1
7/20/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (243.00 + 3)] x (12 in./ft.)3 = 1.55 ft3
Volumespan = N[A x L] = 1 x [10.88 x 243.00] x (12 in./ft.)3 = 1.53 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.55 = 53.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.53 = 52.3 lbs
0 lbs
150 lbs
ws = 2.58 plf
20.25 ft.
20.50 ft.
101.48 lbs
101.48 lbs
7/20/2023 3
Fbx' = (900)(0.9)(1)(1)(1)(1.2)(1)(1.15) = 1117.8 psi
fb = = 814.4 psi
 fb = 814.4 psi < Fbx' = 1117.8 psi  (CSI = 0.73)   ➜  OK
7/20/2023 4
fv* = = 13.74 psi
 fv* = 13.74 psi < Fvx' = 162.00 psi  (CSI = 0.08)   ➜  OK
fv = = 13.95 psi
 fv = 13.95 psi < Fvx' = 162.00 psi  (CSI = 0.09)   ➜  OK
7/20/2023 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 243.00 / 0.00 = ∞
 ΔLL = 0.00 in = L/∞ < L/240   ➜  OK
ΔTL =   =   = 0.72 in.
(L/d)TL = 243.00 / 0.72 = 339
 ΔTL = 0.72 in = L/339 < L/180   ➜  OK
fc⊥ = = 22.6 psi
 fc⊥ = 22.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.04)   ➜  OK
7/20/2023 6
