Design Span (L): 17.75 ft.
Clear Span: 17.50 ft.
Total Span: 18.00 ft.
Live Load: 74 plf
Dead Load: 20 plf
Selfweight: 142.3 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 144.3 lbs
Incised Lumber: Yes
Beam Design 2023A304
7/20/2023 1
7/20/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (213.00 + 3)] x (12 in./ft.)3 = 4.22 ft3
Volumespan = N[A x L] = 2 x [16.88 x 213.00] x (12 in./ft.)3 = 4.16 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.22 = 144.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.16 = 142.3 lbs
74 plf
20 plf
ws = 8.02 plf
17.75 ft.
17.50 ft.
18.00 ft.
918.15 lbs
918.15 lbs
7/20/2023 3
Fbx' = (900)(1.15)(1)(1)(1)(1)(0.8)(1) = 828.0 psi
fb = = 761.9 psi
 fb = 761.9 psi < Fbx' = 828.0 psi  (CSI = 0.92)   ➜  OK
7/20/2023 4
Fvx' = (180)(1.15)(1)(1)(0.8) = 165.60 psi
fv* = = 35.99 psi
 fv* = 35.99 psi < Fvx' = 165.60 psi  (CSI = 0.22)   ➜  OK
fv = = 40.24 psi
 fv = 40.24 psi < Fvx' = 165.60 psi  (CSI = 0.24)   ➜  OK
7/20/2023 5
ΔLL = = 0.31 in.
(L/d)LL = 213.00 / 0.31 = 697
 ΔLL = 0.31 in = L/697 < L/180   ➜  OK
ΔTL = = 0.42 in.
(L/d)TL = 213.00 / 0.42 = 506
 ΔTL = 0.42 in = L/506 < L/120   ➜  OK
fc⊥ = = 102.0 psi
 fc⊥ = 102.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
7/20/2023 6
