Size: 3.125 x 12
Design Span (L): 20.75 ft.
Clear Span: 20.50 ft.
Total Span: 21.00 ft.
Selfweight: 182.4 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 184.6 lbs
Beam Design 2023A302
7/14/2023 1
b = 3.125 in.
7/14/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (249.00 + 3)] x (12 in./ft.)3 = 5.47 ft3
Volumespan = N[A x L] = 1 x [37.50 x 249.00] x (12 in./ft.)3 = 5.40 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.47 = 184.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.40 = 182.4 lbs
  ws = 8.79 plf
20.75 ft.
20.50 ft.
21.00 ft.
1929.82 lbs
1929.82 lbs
7/14/2023 3
fb = = 1582.7 psi
 fb = 1582.7 psi < Fbx' = 2760.0 psi  (CSI = 0.57)   ➜  OK
7/14/2023 4
fv* = = 68.92 psi
 fv* = 68.92 psi < Fvx' = 304.75 psi  (CSI = 0.23)   ➜  OK
fv = = 76.27 psi
 fv = 76.27 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
7/14/2023 5
ΔLL = = 0.51 in.
(L/d)LL = 249.00 / 0.51 = 484
 ΔLL = 0.51 in = L/484 < L/360   ➜  OK
ΔTL = = 0.95 in.
(L/d)TL = 249.00 / 0.95 = 263
 ΔTL = 0.95 in = L/263 < L/240   ➜  OK
fc⊥ = = 205.8 psi
 fc⊥ = 205.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.32)   ➜  OK
7/14/2023 6
