Grade: DF No.1 & Btr
Size: 4 x 10
Design Span (L): 13.17 ft.
Clear Span: 12.83 ft.
Total Span: 13.50 ft.
Bearing (lb): 4 in.
Live Load: 6500 lbs
Dead Load: 75 lbs
Selfweight: 101.3 lbs
Dist. Selfweight: 7.69 plf
Total Weight: 103.8 lbs
Load Duration: 1.60
Beam Design 2023A300
7/14/2023 1
7/14/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (158.00 + 4)] x (12 in./ft.)3 = 3.04 ft3
Volumespan = N[A x L] = 1 x [32.38 x 158.00] x (12 in./ft.)3 = 2.96 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.04 = 103.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.96 = 101.3 lbs
6500 lbs
75 lbs
ws = 7.69 plf
13.17 ft.
12.83 ft.
13.50 ft.
3339.41 lbs
3339.41 lbs
7/14/2023 3
Fbx' = (1200)(1.60)(1)(1)(1)(1.2)(1)(1) = 2304.0 psi
fb = = 5243.7 psi
 fb = 5243.7 psi > Fbx' = 2304.0 psi  (CSI = 2.28)   ➜  NG
7/14/2023 4
Fvx' = (180)(1.60)(1)(1)(1) = 288.00 psi
fv* = = 154.39 psi
 fv* = 154.39 psi < Fvx' = 288.00 psi  (CSI = 0.54)   ➜  OK
fv = = 154.66 psi
 fv = 154.66 psi < Fvx' = 288.00 psi  (CSI = 0.54)   ➜  OK
7/14/2023 5
ΔLL =   =   = 1.29 in.
(L/d)LL = 158.00 / 1.29 = 123
 ΔLL = 1.29 in = L/123 > L/360   ➜  NG
ΔTL =   =   = 1.31 in.
(L/d)TL = 158.00 / 1.31 = 120
 ΔTL = 1.31 in = L/120 > L/240   ➜  NG
Ab = b x lb = 3.5 x 4 = 14.00 in2
fc⊥ = = 238.5 psi
 fc⊥ = 238.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.38)   ➜  OK
7/14/2023 6
