Live Load: 275 plf
Dead Load: 120 plf
Selfweight: 46.1 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 47.0 lbs
Incised Lumber: Yes
Beam Design 2023A298
7/10/2023 1
7/10/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (141.00 + 3)] x (12 in./ft.)3 = 1.38 ft3
Volumespan = N[A x L] = 2 x [8.25 x 141.00] x (12 in./ft.)3 = 1.35 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.38 = 47.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.35 = 46.1 lbs
275 plf
120 plf
ws = 3.92 plf
2393.51 lbs
2393.51 lbs
7/10/2023 3
Fbx' = (900)(1.00)(1)(1)(1)(1.3)(0.8)(1) = 936.0 psi
fb = = 5462.1 psi
 fb = 5462.1 psi > Fbx' = 936.0 psi  (CSI = 5.84)   ➜  NG
7/10/2023 4
Fvx' = (180)(1.00)(1)(1)(0.8) = 144.00 psi
fv* = = 196.44 psi
 fv* = 196.44 psi > Fvx' = 144.00 psi  (CSI = 1.36)   ➜  NG
fv = = 213.06 psi
 fv = 213.06 psi > Fvx' = 144.00 psi  (CSI = 1.48)   ➜  NG
7/10/2023 5
ΔLL = = 1.87 in.
(L/d)LL = 141.00 / 1.87 = 76
 ΔLL = 1.87 in = L/76 > L/180   ➜  NG
ΔTL = = 2.71 in.
(L/d)TL = 141.00 / 2.71 = 52
 ΔTL = 2.71 in = L/52 > L/120   ➜  NG
fc⊥ = = 265.9 psi
 fc⊥ = 265.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.43)   ➜  OK
7/10/2023 6
