Design Span (L): 22.00 ft.
Clear Span: 20.00 ft.
Total Span: 24.00 ft.
Bearing (lb): 24 in.
Live Load: 650 plf
Selfweight: 72.5 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 79.1 lbs
Beam Design 2023A294
7/7/2023 1
7/7/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (264.00 + 24)] x (12 in./ft.)3 = 2.31 ft3
Volumespan = N[A x L] = 1 x [13.88 x 264.00] x (12 in./ft.)3 = 2.12 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.31 = 79.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.12 = 72.5 lbs
650 plf
ws = 3.30 plf
22.00 ft.
24.00 ft.
8739.55 lbs
8739.55 lbs
7/7/2023 3
fb = = 24718.4 psi
 fb = 24718.4 psi > Fbx' = 1138.5 psi  (CSI = 21.71)   ➜  NG
7/7/2023 4
fv* = = 805.39 psi
 fv* = 805.39 psi > Fvx' = 207.00 psi  (CSI = 3.89)   ➜  NG
fv = = 866.08 psi
 fv = 866.08 psi > Fvx' = 207.00 psi  (CSI = 4.18)   ➜  NG
7/7/2023 5
ΔLL = = 21.64 in.
(L/d)LL = 264.00 / 21.64 = 12
 ΔLL = 21.64 in = L/12 > L/360   ➜  NG
ΔTL = = 24.25 in.
(L/d)TL = 264.00 / 24.25 = 11
 ΔTL = 24.25 in = L/11 > L/240   ➜  NG
Ab = b x lb = 1.5 x 24 = 36.00 in2
fc⊥ = = 242.8 psi
 fc⊥ = 242.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.39)   ➜  OK
7/7/2023 6
