Beam Design - Gladimar Deck
Design Span (L): 27.25 ft.
Clear Span: 27.00 ft.
Total Span: 27.50 ft.
Live Load: 134 plf
Dead Load: 20 plf
Selfweight: 89.8 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 90.6 lbs
Load Duration: 1.60
Orientation: Horizontal
Notes: Ledger Design
Beam Design Gladimar Santiago 23-001
7/6/2023 1
7/6/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (327.00 + 3)] x (12 in./ft.)3 = 2.65 ft3
Volumespan = N[A x L] = 1 x [13.88 x 327.00] x (12 in./ft.)3 = 2.63 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.65 = 90.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.63 = 89.8 lbs
134 plf
20 plf
ws = 3.30 plf
27.25 ft.
27.00 ft.
27.50 ft.
2162.82 lbs
2162.82 lbs
7/6/2023 3
Fby' = (900)(1.60)(1)(1)(1)(1.1)(1.2)(1)(1) = 1900.8 psi
fb = = 50508.9 psi
 fb = 50508.9 psi > Fby' = 1900.8 psi  (CSI = 26.57)   ➜  NG
7/6/2023 4
Fvy' = (180)(1.60)(1)(1)(1) = 288.00 psi
fv* = = 229.57 psi
 fv* = 229.57 psi < Fvy' = 288.00 psi  (CSI = 0.80)   ➜  OK
fv = = 231.69 psi
 fv = 231.69 psi < Fvy' = 288.00 psi  (CSI = 0.80)   ➜  OK
7/6/2023 5
ΔLL = = 399.39 in.
(L/d)LL = 327.00 / 399.39 = 1
 ΔLL = 399.39 in = L/1 > L/360   ➜  NG
ΔTL = = 468.83 in.
(L/d)TL = 327.00 / 468.83 = 1
 ΔTL = 468.83 in = L/1 > L/240   ➜  NG
Ab = d x lb = 9.25 x 3 = 27.75 in2
fc⊥ = = 77.9 psi
 fc⊥ = 77.9 psi < Fc⊥y' = 625.00 psi  (CSI = 0.12)   ➜  OK
7/6/2023 6
