Size: 4 x 6
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Selfweight: 37.7 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 38.9 lbs
Beam Design 2023A29
2/12/2023 1
Beam Design 2023A29
2/12/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (99.00 + 3)] x (12 in./ft.)3 = 1.14 ft3
Volumespan = N[A x L] = 1 x [19.25 x 99.00] x (12 in./ft.)3 = 1.10 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.14 = 38.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.10 = 37.7 lbs
ws = 4.57 plf
8.25 ft.
8.50 ft.
763.18 lbs
763.18 lbs
Beam Design 2023A29
2/12/2023 3
fb = = 1039.0 psi
 fb = 1039.0 psi < Fbx' = 1170.0 psi  (CSI = 0.89)   ➜  OK
Beam Design 2023A29
2/12/2023 4
fv* = = 51.31 psi
 fv* = 51.31 psi < Fvx' = 180.00 psi  (CSI = 0.29)   ➜  OK
fv = = 57.72 psi
 fv = 57.72 psi < Fvx' = 180.00 psi  (CSI = 0.32)   ➜  OK
Beam Design 2023A29
2/12/2023 5
ΔLL = = 0.13 in.
(L/d)LL = 99.00 / 0.13 = 737
 ΔLL = 0.13 in = L/737 < L/360   ➜  OK
ΔTL = = 0.24 in.
(L/d)TL = 99.00 / 0.24 = 411
 ΔTL = 0.24 in = L/411 < L/240   ➜  OK
fc⊥ = = 72.7 psi
 fc⊥ = 72.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.12)   ➜  OK
Beam Design 2023A29
2/12/2023 6
