Beam Design - Beam Load Assessment
Size: 5.125 x 15
Design Span (L): 13.96 ft.
Clear Span: 13.50 ft.
Total Span: 14.42 ft.
Bearing (lb): 5.5 in.
Live Load: 564.375 plf
Dead Load: 892.5 plf
Selfweight: 251.6 lbs
Dist. Selfweight: 18.02 plf
Total Weight: 259.9 lbs
Notes: Beam Load Assessment to Replace Chimney
Beam Design John Susko 35000023
6/29/2023 1
b = 5.125 in.
d = 15.000 in.
A = 5.125 x 15.000 = 76.88 in.2
Sx = (5.125)(15.000)2/6 = 192.19 in.3
Sy = (5.125)2(15.000)/6 = 65.66 in.3
Ix = (5.125)(15.000)3/12 = 1441.41 in.4
Iy = (5.125)3(15.000)/12 = 168.26 in.4
6/29/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [76.88 x (167.54 + 5.5)] x (12 in./ft.)3 = 7.70 ft3
Volumespan = N[A x L] = 1 x [76.88 x 167.54] x (12 in./ft.)3 = 7.45 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.70 = 259.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.45 = 251.6 lbs
Distributed Self Weight (ws) = = 18.02 plf
564.375 plf
892.5 plf
  ws = 18.02 plf
13.96 ft.
13.50 ft.
14.42 ft.
10634.26 lbs
10634.26 lbs
6/29/2023 3
fb = = 2244.0 psi
 fb = 2244.0 psi < Fbx' = 2760.0 psi  (CSI = 0.81)   ➜  OK
6/29/2023 4
fv* = = 164.93 psi
 fv* = 164.93 psi < Fvx' = 304.75 psi  (CSI = 0.54)   ➜  OK
fv = = 200.90 psi
 fv = 200.90 psi < Fvx' = 304.75 psi  (CSI = 0.66)   ➜  OK
6/29/2023 5
ΔLL = = 0.19 in.
(L/d)LL = 167.54 / 0.19 = 901
 ΔLL = 0.19 in = L/901 < L/360   ➜  OK
ΔTL = = 0.49 in.
(L/d)TL = 167.54 / 0.49 = 345
 ΔTL = 0.49 in = L/345 < L/240   ➜  OK
fc⊥ = = 377.3 psi
 fc⊥ = 377.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.58)   ➜  OK
6/29/2023 6
