Beam Design - Beam Load Assessment
Size: 5.125 x 16.5
Design Span (L): 14.38 ft.
Clear Span: 13.92 ft.
Total Span: 14.84 ft.
Bearing (lb): 5.5 in.
Live Load: 564.4 plf
Dead Load: 892.5 plf
Selfweight: 285.1 lbs
Dist. Selfweight: 19.83 plf
Total Weight: 294.1 lbs
Defl. Limits: 480|360
Notes: Remove fireplace. Replace with beam
Beam Design John Susko 20230523-35000023
6/29/2023 1
b = 5.125 in.
d = 16.500 in.
A = 5.125 x 16.500 = 84.56 in.2
Sx = (5.125)(16.500)2/6 = 232.55 in.3
Sy = (5.125)2(16.500)/6 = 72.23 in.3
Ix = (5.125)(16.500)3/12 = 1918.51 in.4
Iy = (5.125)3(16.500)/12 = 185.09 in.4
6/29/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [84.56 x (172.54 + 5.5)] x (12 in./ft.)3 = 8.71 ft3
Volumespan = N[A x L] = 1 x [84.56 x 172.54] x (12 in./ft.)3 = 8.44 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.71 = 294.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.44 = 285.1 lbs
Distributed Self Weight (ws) = = 19.83 plf
564.4 plf
892.5 plf
  ws = 19.83 plf
14.38 ft.
13.92 ft.
14.84 ft.
10954.60 lbs
10954.60 lbs
6/29/2023 3
fb = = 1969.1 psi
 fb = 1969.1 psi < Fbx' = 2760.0 psi  (CSI = 0.71)   ➜  OK
6/29/2023 4
fv* = = 152.30 psi
 fv* = 152.30 psi < Fvx' = 304.75 psi  (CSI = 0.50)   ➜  OK
fv = = 188.31 psi
 fv = 188.31 psi < Fvx' = 304.75 psi  (CSI = 0.62)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
6/29/2023 5
ΔLL = = 0.16 in.
(L/d)LL = 172.54 / 0.16 = 1098
 ΔLL = 0.16 in = L/1098 < L/480   ➜  OK
ΔTL = = 0.41 in.
(L/d)TL = 172.54 / 0.41 = 420
 ΔTL = 0.41 in = L/420 < L/360   ➜  OK
fc⊥ = = 388.6 psi
 fc⊥ = 388.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.60)   ➜  OK
6/29/2023 6
