Beam Design - Beam Load Assessment
Size: 3.125 x 18
Design Span (L): 12.67 ft.
Clear Span: 12.21 ft.
Total Span: 13.13 ft.
Bearing (lb): 5.5 in.
Live Load: 1693 plf
Dead Load: 1532 plf
Selfweight: 334.1 lbs
Dist. Selfweight: 26.38 plf
Total Weight: 346.2 lbs
Defl. Limits: 480|360
Notes: Remove fireplace. Replace with beam
Beam Design John Susko 20230523-35000023
6/29/2023 1
b = 3.125 in.
d = 18.000 in.
A = 3.125 x 18.000 = 56.25 in.2
Sx = (3.125)(18.000)2/6 = 168.75 in.3
Sy = (3.125)2(18.000)/6 = 29.30 in.3
Ix = (3.125)(18.000)3/12 = 1518.75 in.4
Iy = (3.125)3(18.000)/12 = 45.78 in.4
6/29/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [56.25 x (152.00 + 5.5)] x (12 in./ft.)3 = 10.25 ft3
Volumespan = N[A x L] = 2 x [56.25 x 152.00] x (12 in./ft.)3 = 9.90 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 10.25 = 346.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.90 = 334.1 lbs
Distributed Self Weight (ws) = = 26.38 plf
1693 plf
1532 plf
  ws = 26.38 plf
12.67 ft.
12.21 ft.
13.13 ft.
21337.70 lbs
21337.70 lbs
6/29/2023 3
fb = = 2318.6 psi
 fb = 2318.6 psi < Fbx' = 2760.0 psi  (CSI = 0.84)   ➜  OK
6/29/2023 4
fv* = = 209.54 psi
 fv* = 209.54 psi < Fvx' = 304.75 psi  (CSI = 0.69)   ➜  OK
fv = = 274.57 psi
 fv = 274.57 psi < Fvx' = 304.75 psi  (CSI = 0.90)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
6/29/2023 5
ΔLL = = 0.18 in.
(L/d)LL = 152.00 / 0.18 = 847
 ΔLL = 0.18 in = L/847 < L/480   ➜  OK
ΔTL = = 0.34 in.
(L/d)TL = 152.00 / 0.34 = 441
 ΔTL = 0.34 in = L/441 < L/360   ➜  OK
Ab = b x lb = 3.125 x 5.5 = 17.19 in2
fc⊥ = = 620.7 psi
 fc⊥ = 620.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.95)   ➜  OK
6/29/2023 6
