Size: 3.125 x 9
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 388 lbs
Dead Load: 1223 lbs
Selfweight: 84.1 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 85.7 lbs
Beam Design 2023A280
6/28/2023 1
b = 3.125 in.
d = 9.000 in.
A = 3.125 x 9.000 = 28.13 in.2
Sx = (3.125)(9.000)2/6 = 42.19 in.3
Sy = (3.125)2(9.000)/6 = 14.65 in.3
Ix = (3.125)(9.000)3/12 = 189.84 in.4
Iy = (3.125)3(9.000)/12 = 22.89 in.4
6/28/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [28.13 x (153.00 + 3)] x (12 in./ft.)3 = 2.54 ft3
Volumespan = N[A x L] = 1 x [28.13 x 153.00] x (12 in./ft.)3 = 2.49 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.54 = 85.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.49 = 84.1 lbs
388 lbs
1223 lbs
  ws = 6.59 plf
12.75 ft.
12.50 ft.
13.00 ft.
848.36 lbs
848.36 lbs
6/28/2023 3
fb = = 1498.8 psi
 fb = 1498.8 psi < Fbx' = 2760.0 psi  (CSI = 0.54)   ➜  OK
6/28/2023 4
fv* = = 44.94 psi
 fv* = 44.94 psi < Fvx' = 304.75 psi  (CSI = 0.15)   ➜  OK
fv = = 45.20 psi
 fv = 45.20 psi < Fvx' = 304.75 psi  (CSI = 0.15)   ➜  OK
6/28/2023 5
ΔLL =   =   = 0.08 in.
(L/d)LL = 153.00 / 0.08 = 1806
 ΔLL = 0.08 in = L/1806 < L/360   ➜  OK
ΔTL =   =   = 0.36 in.
(L/d)TL = 153.00 / 0.36 = 421
 ΔTL = 0.36 in = L/421 < L/240   ➜  OK
fc⊥ = = 90.5 psi
 fc⊥ = 90.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.14)   ➜  OK
6/28/2023 6
