Size: 5.125 x 13.5
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 388 lbs
Dead Load: 135 lbs
Selfweight: 206.8 lbs
Dist. Selfweight: 16.22 plf
Total Weight: 210.9 lbs
Beam Design 2023A278
6/28/2023 1
b = 5.125 in.
d = 13.500 in.
A = 5.125 x 13.500 = 69.19 in.2
Sx = (5.125)(13.500)2/6 = 155.67 in.3
Sy = (5.125)2(13.500)/6 = 59.10 in.3
Ix = (5.125)(13.500)3/12 = 1050.79 in.4
Iy = (5.125)3(13.500)/12 = 151.44 in.4
6/28/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [69.19 x (153.00 + 3)] x (12 in./ft.)3 = 6.25 ft3
Volumespan = N[A x L] = 1 x [69.19 x 153.00] x (12 in./ft.)3 = 6.13 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.25 = 210.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.13 = 206.8 lbs
Distributed Self Weight (ws) = = 16.22 plf
388 lbs
135 lbs
  ws = 16.22 plf
12.75 ft.
12.50 ft.
13.00 ft.
366.94 lbs
366.94 lbs
6/28/2023 3
fb = = 153.9 psi
 fb = 153.9 psi < Fbx' = 2760.0 psi  (CSI = 0.06)   ➜  OK
6/28/2023 4
fv* = = 7.52 psi
 fv* = 7.52 psi < Fvx' = 304.75 psi  (CSI = 0.02)   ➜  OK
fv = = 7.91 psi
 fv = 7.91 psi < Fvx' = 304.75 psi  (CSI = 0.03)   ➜  OK
6/28/2023 5
ΔLL =   =   = 0.02 in.
(L/d)LL = 153.00 / 0.02 = 9996
 ΔLL = 0.02 in = L/9996 < L/360   ➜  OK
ΔTL =   =   = 0.03 in.
(L/d)TL = 153.00 / 0.03 = 5946
 ΔTL = 0.03 in = L/5946 < L/240   ➜  OK
fc⊥ = = 23.9 psi
 fc⊥ = 23.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.04)   ➜  OK
6/28/2023 6
