Size: 3.5 x 6
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 288 plf
Dead Load: 115 plf
Selfweight: 28.3 lbs
Dist. Selfweight: 4.92 plf
Total Weight: 29.5 lbs
Beam Design 2023A276
6/28/2023 1
d = 6.000 in.
A = 3.500 x 6.000 = 21.00 in.2
Sx = (3.500)(6.000)2/6 = 21.00 in.3
Sy = (3.500)2(6.000)/6 = 12.25 in.3
Ix = (3.500)(6.000)3/12 = 63.00 in.4
Iy = (3.500)3(6.000)/12 = 21.44 in.4
6/28/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [21.00 x (69.00 + 3)] x (12 in./ft.)3 = 0.88 ft3
Volumespan = N[A x L] = 1 x [21.00 x 69.00] x (12 in./ft.)3 = 0.84 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 0.88 = 29.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 0.84 = 28.3 lbs
Distributed Self Weight (ws) = = 4.92 plf
288 plf
115 plf
  ws = 4.92 plf
5.75 ft.
5.50 ft.
1223.77 lbs
1223.77 lbs
6/28/2023 3
fb = = 963.4 psi
 fb = 963.4 psi < Fbx' = 2760.0 psi  (CSI = 0.35)   ➜  OK
6/28/2023 4
fv* = = 69.20 psi
 fv* = 69.20 psi < Fvx' = 304.75 psi  (CSI = 0.23)   ➜  OK
fv = = 83.77 psi
 fv = 83.77 psi < Fvx' = 304.75 psi  (CSI = 0.27)   ➜  OK
6/28/2023 5
ΔLL = = 0.06 in.
(L/d)LL = 69.00 / 0.06 = 1105
 ΔLL = 0.06 in = L/1105 < L/360   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 69.00 / 0.09 = 780
 ΔTL = 0.09 in = L/780 < L/240   ➜  OK
fc⊥ = = 116.5 psi
 fc⊥ = 116.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.18)   ➜  OK
6/28/2023 6
