Beam Design - Entry Hall Beam
Grade: SP DSS
Design Span (L): 9.25 ft.
Clear Span: 9.00 ft.
Total Span: 9.50 ft.
Live Load: 520 plf
Dead Load: 230 plf
Selfweight: 121.4 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 124.7 lbs
Notes: 3128 Avenue O
Galveston Texas 77550
Beam Design Cheryl Crider 023.312
6/23/2023 1
6/23/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (111.00 + 3)] x (12 in./ft.)3 = 3.34 ft3
Volumespan = N[A x L] = 3 x [16.88 x 111.00] x (12 in./ft.)3 = 3.25 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.34 = 124.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.25 = 121.4 lbs
520 plf
230 plf
ws = 13.12 plf
9.25 ft.
9.00 ft.
9.50 ft.
3624.84 lbs
3624.84 lbs
6/23/2023 3
Fbx' = (1800)(1.00)(1)(1)(1)(1)(1)(1) = 1800.0 psi
fb = = 1031.8 psi
 fb = 1031.8 psi < Fbx' = 1800.0 psi  (CSI = 0.57)   ➜  OK
6/23/2023 4
fv* = = 83.38 psi
 fv* = 83.38 psi < Fvx' = 175.00 psi  (CSI = 0.48)   ➜  OK
fv = = 104.58 psi
 fv = 104.58 psi < Fvx' = 175.00 psi  (CSI = 0.60)   ➜  OK
6/23/2023 5
ΔLL = = 0.08 in.
(L/d)LL = 111.00 / 0.08 = 1315
 ΔLL = 0.08 in = L/1315 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 111.00 / 0.12 = 896
 ΔTL = 0.12 in = L/896 < L/240   ➜  OK
fc⊥ = = 268.5 psi
 fc⊥ = 268.5 psi < Fc⊥x' = 660.00 psi  (CSI = 0.41)   ➜  OK
6/23/2023 6
