Beam Design - Beam Calc Short
Size: 3.5 x 18
Design Span (L): 13.38 ft.
Clear Span: 13.13 ft.
Total Span: 13.63 ft.
Live Load: 423.75 plf
Dead Load: 996.5 plf
Selfweight: 395.1 lbs
Dist. Selfweight: 29.54 plf
Total Weight: 402.5 lbs
Defl. Limits: 480|360
Beam Design John Susko 11623
6/21/2023 1
d = 18.000 in.
A = 3.500 x 18.000 = 63.00 in.2
Sx = (3.500)(18.000)2/6 = 189.00 in.3
Sy = (3.500)2(18.000)/6 = 36.75 in.3
Ix = (3.500)(18.000)3/12 = 1701.00 in.4
Iy = (3.500)3(18.000)/12 = 64.31 in.4
6/21/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [63.00 x (160.50 + 3)] x (12 in./ft.)3 = 11.92 ft3
Volumespan = N[A x L] = 2 x [63.00 x 160.50] x (12 in./ft.)3 = 11.70 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.92 = 402.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 11.70 = 395.1 lbs
Distributed Self Weight (ws) = = 29.54 plf
423.75 plf
996.5 plf
  ws = 29.54 plf
13.38 ft.
13.13 ft.
13.63 ft.
9876.70 lbs
9876.70 lbs
6/21/2023 3
fb = = 1029.2 psi
 fb = 1029.2 psi < Fbx' = 2760.0 psi  (CSI = 0.37)   ➜  OK
6/21/2023 4
fv* = = 89.53 psi
 fv* = 89.53 psi < Fvx' = 304.75 psi  (CSI = 0.29)   ➜  OK
fv = = 115.42 psi
 fv = 115.42 psi < Fvx' = 304.75 psi  (CSI = 0.38)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
6/21/2023 5
ΔLL = = 0.05 in.
(L/d)LL = 160.50 / 0.05 = 3221
 ΔLL = 0.05 in = L/3221 < L/480   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 160.50 / 0.17 = 941
 ΔTL = 0.17 in = L/941 < L/360   ➜  OK
fc⊥ = = 470.3 psi
 fc⊥ = 470.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.72)   ➜  OK
6/21/2023 6
