Beam Design - Beam Load Assessment
Size: 6.75 x 13.5
Design Span (L): 14.36 ft.
Clear Span: 13.90 ft.
Total Span: 14.82 ft.
Bearing (lb): 5.5 in.
Live Load: 1693 plf
Dead Load: 1532 plf
Selfweight: 920.3 lbs
Dist. Selfweight: 64.09 plf
Total Weight: 949.6 lbs
Defl. Limits: 480|360
Notes: Remove wall replace with beam
CV Volume Factor 0.999b - - - - -
Beam Design John Susko 20230523-35000023
6/15/2023 1
b = 6.750 in.
d = 13.500 in.
A = 6.750 x 13.500 = 91.13 in.2
Sx = (6.750)(13.500)2/6 = 205.03 in.3
Sy = (6.750)2(13.500)/6 = 102.52 in.3
Ix = (6.750)(13.500)3/12 = 1383.96 in.4
Iy = (6.750)3(13.500)/12 = 345.99 in.4
6/15/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [91.13 x (172.30 + 5.5)] x (12 in./ft.)3 = 28.13 ft3
Volumespan = N[A x L] = 3 x [91.13 x 172.30] x (12 in./ft.)3 = 27.26 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 28.13 = 949.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 27.26 = 920.3 lbs
Distributed Self Weight (ws) = = 64.09 plf
1693 plf
1532 plf
  ws = 64.09 plf
14.36 ft.
13.90 ft.
14.82 ft.
24366.15 lbs
24366.15 lbs
6/15/2023 3
CV = = 0.999
CV = 0.999 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.999) = 2756.4 psi
fb = = 1653.5 psi
 fb = 1653.5 psi < Fbx' = 2756.4 psi  (CSI = 0.60)   ➜  OK
6/15/2023 4
fv* = = 109.26 psi
 fv* = 109.26 psi < Fvx' = 304.75 psi  (CSI = 0.36)   ➜  OK
fv = = 129.56 psi
 fv = 129.56 psi < Fvx' = 304.75 psi  (CSI = 0.43)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
6/15/2023 5
ΔLL = = 0.22 in.
(L/d)LL = 172.30 / 0.22 = 795
 ΔLL = 0.22 in = L/795 < L/480   ➜  OK
ΔTL = = 0.42 in.
(L/d)TL = 172.30 / 0.42 = 409
 ΔTL = 0.42 in = L/409 < L/360   ➜  OK
Ab = b x lb = 6.75 x 5.5 = 37.13 in2
fc⊥ = = 218.8 psi
 fc⊥ = 218.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.34)   ➜  OK
6/15/2023 6
