Beam Design - Beam Load Assessment
Size: 6.75 x 24
Design Span (L): 26.29 ft.
Clear Span: 25.83 ft.
Total Span: 26.75 ft.
Bearing (lb): 5.5 in.
Live Load: 1693 plf
Dead Load: 1532 plf
Selfweight: 2995.8 lbs
Dist. Selfweight: 113.94 plf
Total Weight: 3048.0 lbs
Defl. Limits: 480|360
Notes: Remove wall replace with beam
CV Volume Factor 0.888b - - - - -
Beam Design John Susko 20230523-35000023
6/15/2023 1
b = 6.750 in.
d = 24.000 in.
A = 6.750 x 24.000 = 162.00 in.2
Sx = (6.750)(24.000)2/6 = 648.00 in.3
Sy = (6.750)2(24.000)/6 = 182.25 in.3
Ix = (6.750)(24.000)3/12 = 7776.00 in.4
Iy = (6.750)3(24.000)/12 = 615.09 in.4
6/15/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [162.00 x (315.50 + 5.5)] x (12 in./ft.)3 = 90.28 ft3
Volumespan = N[A x L] = 3 x [162.00 x 315.50] x (12 in./ft.)3 = 88.74 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 90.28 = 3048.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 88.74 = 2995.8 lbs
Distributed Self Weight (ws) = = 113.94 plf
1693 plf
1532 plf
  ws = 113.94 plf
26.29 ft.
25.83 ft.
26.75 ft.
44658.93 lbs
44658.93 lbs
6/15/2023 3
CV = = 0.888
CV = 0.888 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.888) = 2449.5 psi
fb = = 1780.9 psi
 fb = 1780.9 psi < Fbx' = 2449.5 psi  (CSI = 0.73)   ➜  OK
6/15/2023 4
fv* = = 114.86 psi
 fv* = 114.86 psi < Fvx' = 304.75 psi  (CSI = 0.38)   ➜  OK
fv = = 135.47 psi
 fv = 135.47 psi < Fvx' = 304.75 psi  (CSI = 0.44)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
6/15/2023 5
ΔLL = = 0.43 in.
(L/d)LL = 315.50 / 0.43 = 728
 ΔLL = 0.43 in = L/728 < L/480   ➜  OK
ΔTL = = 0.85 in.
(L/d)TL = 315.50 / 0.85 = 369
 ΔTL = 0.85 in = L/369 < L/360   ➜  OK
Ab = b x lb = 6.75 x 5.5 = 37.13 in2
fc⊥ = = 401.0 psi
 fc⊥ = 401.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.62)   ➜  OK
6/15/2023 6
