Size: 3.5 x 12
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 338 plf
Dead Load: 138 plf
Selfweight: 125.5 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 128.0 lbs
Beam Design 2023A264
6/14/2023 1
6/14/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (153.00 + 3)] x (12 in./ft.)3 = 3.79 ft3
Volumespan = N[A x L] = 1 x [42.00 x 153.00] x (12 in./ft.)3 = 3.72 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.79 = 128.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.72 = 125.5 lbs
338 plf
138 plf
  ws = 9.85 plf
12.75 ft.
12.50 ft.
13.00 ft.
3158.01 lbs
3158.01 lbs
6/14/2023 3
fb = = 1410.4 psi
 fb = 1410.4 psi < Fbx' = 2760.0 psi  (CSI = 0.51)   ➜  OK
6/14/2023 4
fv* = = 93.27 psi
 fv* = 93.27 psi < Fvx' = 304.75 psi  (CSI = 0.31)   ➜  OK
fv = = 110.62 psi
 fv = 110.62 psi < Fvx' = 304.75 psi  (CSI = 0.36)   ➜  OK
6/14/2023 5
ΔLL = = 0.22 in.
(L/d)LL = 153.00 / 0.22 = 691
 ΔLL = 0.22 in = L/691 < L/360   ➜  OK
ΔTL = = 0.32 in.
(L/d)TL = 153.00 / 0.32 = 480
 ΔTL = 0.32 in = L/480 < L/240   ➜  OK
fc⊥ = = 300.8 psi
 fc⊥ = 300.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.46)   ➜  OK
6/14/2023 6
