Size: 3.5 x 13.5
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 338 plf
Dead Load: 135 plf
Selfweight: 141.2 lbs
Dist. Selfweight: 11.08 plf
Total Weight: 144.0 lbs
Beam Design 2023A261
6/13/2023 1
d = 13.500 in.
A = 3.500 x 13.500 = 47.25 in.2
Sx = (3.500)(13.500)2/6 = 106.31 in.3
Sy = (3.500)2(13.500)/6 = 27.56 in.3
Ix = (3.500)(13.500)3/12 = 717.61 in.4
Iy = (3.500)3(13.500)/12 = 48.23 in.4
6/13/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [47.25 x (153.00 + 3)] x (12 in./ft.)3 = 4.27 ft3
Volumespan = N[A x L] = 1 x [47.25 x 153.00] x (12 in./ft.)3 = 4.18 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.27 = 144.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.18 = 141.2 lbs
Distributed Self Weight (ws) = = 11.08 plf
338 plf
135 plf
  ws = 11.08 plf
12.75 ft.
12.50 ft.
13.00 ft.
3146.51 lbs
3146.51 lbs
6/13/2023 3
fb = = 1110.3 psi
 fb = 1110.3 psi < Fbx' = 2760.0 psi  (CSI = 0.40)   ➜  OK
6/13/2023 4
fv* = = 80.68 psi
 fv* = 80.68 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
fv = = 97.97 psi
 fv = 97.97 psi < Fvx' = 304.75 psi  (CSI = 0.32)   ➜  OK
6/13/2023 5
ΔLL = = 0.16 in.
(L/d)LL = 153.00 / 0.16 = 983
 ΔLL = 0.16 in = L/983 < L/360   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 153.00 / 0.22 = 687
 ΔTL = 0.22 in = L/687 < L/240   ➜  OK
fc⊥ = = 299.7 psi
 fc⊥ = 299.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.46)   ➜  OK
6/13/2023 6
