Beam Design - Conricode Basement
Design Span (L): 5.58 ft.
Clear Span: 5.33 ft.
Total Span: 5.83 ft.
Live Load: 563 plf
Dead Load: 464 plf
Selfweight: 44.8 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 46.8 lbs
Beam Design 23-01
2/6/2023 1
Beam Design 23-01
2/6/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (67.00 + 3)] x (12 in./ft.)3 = 1.37 ft3
Volumespan = N[A x L] = 2 x [16.88 x 67.00] x (12 in./ft.)3 = 1.31 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.37 = 46.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.31 = 44.8 lbs
563 plf
464 plf
ws = 8.02 plf
5.58 ft.
5.33 ft.
5.83 ft.
3018.63 lbs
3018.63 lbs
Beam Design 23-01
2/6/2023 3
fb = = 764.7 psi
 fb = 764.7 psi < Fbx' = 900.0 psi  (CSI = 0.85)   ➜  OK
Beam Design 23-01
2/6/2023 4
fv* = = 85.29 psi
 fv* = 85.29 psi < Fvx' = 180.00 psi  (CSI = 0.47)   ➜  OK
fv = = 128.41 psi
 fv = 128.41 psi < Fvx' = 180.00 psi  (CSI = 0.71)   ➜  OK
Beam Design 23-01
2/6/2023 5
ΔLL = = 0.02 in.
(L/d)LL = 67.00 / 0.02 = 3100
 ΔLL = 0.02 in = L/3100 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 67.00 / 0.04 = 1686
 ΔTL = 0.04 in = L/1686 < L/240   ➜  OK
fc⊥ = = 335.4 psi
 fc⊥ = 335.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.54)   ➜  OK
Beam Design 23-01
2/6/2023 6
