Grade: SP No.1
Design Span (L): 8.00 ft.
Clear Span: 7.63 ft.
Total Span: 8.38 ft.
Bearing (lb): 4.5 in.
Live Load: 40 plf
Dead Load: 100 plf
Selfweight: 28.8 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 30.1 lbs
CL Beam Stability Factor 0.757 - - - - -
Beam Design Jason Stevens 3818 Parsons Rd 2023A257
6/10/2023 1
6/10/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (96.00 + 4.5)] x (12 in./ft.)3 = 0.81 ft3
Volumespan = N[A x L] = 1 x [13.88 x 96.00] x (12 in./ft.)3 = 0.77 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.81 = 30.1 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.77 = 28.8 lbs
40 plf
ws = 3.60 plf
7.63 ft.
8.38 ft.
601.31 lbs
601.31 lbs
6/10/2023 3
lu = Unbraced Length = 8.0 ft.
lu/d = = 10.38
le = 1.63lu + 3d = 1.63(96.0) + 3(9.25) = 184.23 in. = 15.35 ft.  (NDS Table 3.3.3)
Rb = = 27.52
 Rb = 27.52 < 50   ➜  OK
6/10/2023 4
FbE = = 918.95 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1050)(1.00)(1)(1)(1)(1)(1) = 1050.00 psi
CL =   = 0.757
Fbx' = (1050)(1.00)(1)(1)(0.757)(1)(1)(1) = 795.0 psi
fb = = 644.5 psi
 fb = 644.5 psi < Fbx' = 795.0 psi  (CSI = 0.81)   ➜  OK
fv* = = 50.13 psi
 fv* = 50.13 psi < Fvx' = 175.00 psi  (CSI = 0.29)   ➜  OK
fv = = 62.10 psi
 fv = 62.10 psi < Fvx' = 175.00 psi  (CSI = 0.35)   ➜  OK
6/10/2023 5
ΔLL = = 0.02 in.
(L/d)LL = 96.00 / 0.02 = 4122
 ΔLL = 0.02 in = L/4122 < L/360   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 96.00 / 0.08 = 1148
 ΔTL = 0.08 in = L/1148 < L/240   ➜  OK
Ab = b x lb = 1.5 x 4.5 = 6.75 in2
fc⊥ = = 89.1 psi
 fc⊥ = 89.1 psi < Fc⊥x' = 565.00 psi  (CSI = 0.16)   ➜  OK
6/10/2023 6
