Grade: SP No.1
Design Span (L): 7.67 ft.
Clear Span: 7.44 ft.
Total Span: 7.90 ft.
Bearing (lb): 2.75 in.
Live Load: 200 plf
Dead Load: 500 plf
Selfweight: 82.8 lbs
Dist. Selfweight: 10.79 plf
Total Weight: 85.2 lbs
Beam Design Jason Stevens 3818 Parsons Rd 2023A256
6/10/2023 1
6/10/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (92.04 + 2.75)] x (12 in./ft.)3 = 2.28 ft3
Volumespan = N[A x L] = 3 x [13.88 x 92.04] x (12 in./ft.)3 = 2.22 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.28 = 85.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.22 = 82.8 lbs
Distributed Self Weight (ws) = = 10.79 plf
200 plf
500 plf
ws = 10.79 plf
7.67 ft.
7.44 ft.
7.90 ft.
2807.33 lbs
2807.33 lbs
6/10/2023 3
lu = Unbraced Length = 7.67 ft.
lu/d = = 9.95
le = 1.63lu + 3d = 1.63(92.0) + 3(9.25) = 177.78 in. = 14.81 ft.  (NDS Table 3.3.3)
Rb = = 9.01
 Rb = 9.01 < 50   ➜  OK
6/10/2023 4
FbE = = 8570.80 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1050)(1.00)(1)(1)(1)(1)(1) = 1050.00 psi
CL =   = 0.993
Fbx' = (1050)(1.00)(1)(1)(0.993)(1)(1)(1) = 1042.8 psi
fb = = 977.4 psi
 fb = 977.4 psi < Fbx' = 1042.8 psi  (CSI = 0.94)   ➜  OK
fv* = = 78.49 psi
 fv* = 78.49 psi < Fvx' = 175.00 psi  (CSI = 0.45)   ➜  OK
fv = = 98.23 psi
 fv = 98.23 psi < Fvx' = 175.00 psi  (CSI = 0.56)   ➜  OK
6/10/2023 5
ΔLL = = 0.03 in.
(L/d)LL = 92.04 / 0.03 = 2806
 ΔLL = 0.03 in = L/2806 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 92.04 / 0.12 = 790
 ΔTL = 0.12 in = L/790 < L/240   ➜  OK
fc⊥ = = 226.9 psi
 fc⊥ = 226.9 psi < Fc⊥x' = 565.00 psi  (CSI = 0.40)   ➜  OK
6/10/2023 6
