Design Span (L): 6.02 ft.
Clear Span: 5.79 ft.
Total Span: 6.25 ft.
Bearing (lb): 2.75 in.
Live Load: 200 plf
Dead Load: 500 plf
Selfweight: 67.2 lbs
Dist. Selfweight: 11.15 plf
Total Weight: 69.7 lbs
Incised Lumber: Yes
Beam Design Jason Stevens 3818 Parsons Rd 2023A251
6/9/2023 1
6/9/2023 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (72.25 + 2.75)] x (12 in./ft.)3 = 1.81 ft3
Volumespan = N[A x L] = 3 x [13.88 x 72.25] x (12 in./ft.)3 = 1.74 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 1.81 = 69.7 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 1.74 = 67.2 lbs
Distributed Self Weight (ws) = = 11.15 plf
200 plf
500 plf
ws = 11.15 plf
6.02 ft.
5.79 ft.
6.25 ft.
2222.41 lbs
2222.41 lbs
6/9/2023 3
lu = Unbraced Length = 6.021 ft.
lu/d = = 7.81
le = 1.63lu + 3d = 1.63(72.3) + 3(9.25) = 145.52 in. = 12.13 ft.  (NDS Table 3.3.3)
Rb = = 8.15
 Rb = 8.15 < 50   ➜  OK
6/9/2023 4
Eminy' = Eminy(CM)(Ct)(Ci) = 510000(0.9)(1)(0.95) = 436050 psi
FbE = = 7871.83 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (800)(1.00)(1)(1)(1)(0.8)(1) = 640.00 psi
CL =   = 0.996
Fbx' = (800)(1.00)(1)(1)(0.996)(1)(0.8)(1) = 637.2 psi
fb = = 602.6 psi
 fb = 602.6 psi < Fbx' = 637.2 psi  (CSI = 0.95)   ➜  OK
Fvx' = (175)(1.00)(0.97)(1)(0.8) = 135.80 psi
fv* = = 57.40 psi
 fv* = 57.40 psi < Fvx' = 135.80 psi  (CSI = 0.42)   ➜  OK
fv = = 77.15 psi
 fv = 77.15 psi < Fvx' = 135.80 psi  (CSI = 0.57)   ➜  OK
6/9/2023 5
Ex' = Ex(CM)(Ct)(Ci) = 1400000(0.9)(1)(0.95) = 1197000 psi
ΔLL = = 0.02 in.
(L/d)LL = 72.25 / 0.02 = 4340
 ΔLL = 0.02 in = L/4340 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 72.25 / 0.06 = 1221
 ΔTL = 0.06 in = L/1221 < L/240   ➜  OK
fc⊥ = = 179.6 psi
 fc⊥ = 179.6 psi < Fc⊥x' = 378.55 psi  (CSI = 0.47)   ➜  OK
6/9/2023 6
