Design Span (L): 10.00 ft.
Clear Span: 9.75 ft.
Total Span: 10.25 ft.
Live Load: 170 plf
Dead Load: 170 plf
Selfweight: 87.5 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 89.7 lbs
CL Beam Stability Factor 0.969 - - - - -
Beam Design 2023A250
6/8/2023 1
6/8/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (120.00 + 3)] x (12 in./ft.)3 = 2.40 ft3
Volumespan = N[A x L] = 2 x [16.88 x 120.00] x (12 in./ft.)3 = 2.34 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.40 = 89.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.34 = 87.5 lbs
170 plf
170 plf
ws = 8.75 plf
10.00 ft.
9.75 ft.
10.25 ft.
1787.34 lbs
1787.34 lbs
6/8/2023 3
lu = Unbraced Length = 10 ft.
lu/d = = 10.67
le = 1.63lu + 3d = 1.63(120.0) + 3(11.25) = 229.35 in. = 19.11 ft.  (NDS Table 3.3.3)
Rb = = 16.93
 Rb = 16.93 < 50   ➜  OK
6/8/2023 4
FbE = = 2134.73 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (750)(1.15)(1)(1)(1)(1)(1) = 862.50 psi
CL =   = 0.969
Fbx' = (750)(1.15)(1)(1)(0.969)(1)(1)(1) = 835.6 psi
fb = = 826.7 psi
 fb = 826.7 psi < Fbx' = 835.6 psi  (CSI = 0.99)   ➜  OK
fv* = = 62.97 psi
 fv* = 62.97 psi < Fvx' = 201.25 psi  (CSI = 0.31)   ➜  OK
fv = = 77.50 psi
 fv = 77.50 psi < Fvx' = 201.25 psi  (CSI = 0.39)   ➜  OK
6/8/2023 5
ΔLL = = 0.08 in.
(L/d)LL = 120.00 / 0.08 = 1563
 ΔLL = 0.08 in = L/1563 < L/360   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 120.00 / 0.16 = 762
 ΔTL = 0.16 in = L/762 < L/240   ➜  OK
fc⊥ = = 198.6 psi
 fc⊥ = 198.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.35)   ➜  OK
6/8/2023 6
