Size: 5.5 x 9
Design Span (L): 18.75 ft.
Clear Span: 18.50 ft.
Total Span: 19.00 ft.
Live Load: 468 plf
Dead Load: 431 plf
Selfweight: 217.6 lbs
Dist. Selfweight: 11.61 plf
Total Weight: 220.5 lbs
Beam Design Peter Truong 101
5/26/2023 1
d = 9.000 in.
5/26/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [49.50 x (225.00 + 3)] x (12 in./ft.)3 = 6.53 ft3
Volumespan = N[A x L] = 1 x [49.50 x 225.00] x (12 in./ft.)3 = 6.45 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.53 = 220.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.45 = 217.6 lbs
Distributed Self Weight (ws) = = 11.61 plf
468 plf
431 plf
  ws = 11.61 plf
18.75 ft.
18.50 ft.
19.00 ft.
8650.75 lbs
8650.75 lbs
5/26/2023 3
fb = = 6467.4 psi
 fb = 6467.4 psi > Fbx' = 2760.0 psi  (CSI = 2.34)   ➜  NG
5/26/2023 4
fv* = = 238.00 psi
 fv* = 238.00 psi < Fvx' = 304.75 psi  (CSI = 0.78)   ➜  OK
fv = = 258.69 psi
 fv = 258.69 psi < Fvx' = 304.75 psi  (CSI = 0.85)   ➜  OK
5/26/2023 5
ΔLL = = 2.16 in.
(L/d)LL = 225.00 / 2.16 = 104
 ΔLL = 2.16 in = L/104 > L/360   ➜  NG
ΔTL = = 4.21 in.
(L/d)TL = 225.00 / 4.21 = 53
 ΔTL = 4.21 in = L/53 > L/240   ➜  NG
fc⊥ = = 524.3 psi
 fc⊥ = 524.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.81)   ➜  OK
5/26/2023 6
