Design Span (L): 9.00 ft.
Clear Span: 8.75 ft.
Total Span: 9.25 ft.
Live Load: 1050 lbs
Dead Load: 262 lbs
Selfweight: 64.7 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 66.5 lbs
Beam Design 2023A239
5/19/2023 1
5/19/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (108.00 + 3)] x (12 in./ft.)3 = 1.78 ft3
Volumespan = N[A x L] = 2 x [13.88 x 108.00] x (12 in./ft.)3 = 1.73 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.78 = 66.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.73 = 64.7 lbs
1050 lbs
262 lbs
ws = 7.19 plf
9.00 ft.
8.75 ft.
9.25 ft.
689.27 lbs
689.27 lbs
5/19/2023 3
fb = = 848.5 psi
 fb = 848.5 psi < Fbx' = 920.0 psi  (CSI = 0.92)   ➜  OK
5/19/2023 4
fv* = = 36.91 psi
 fv* = 36.91 psi < Fvx' = 201.25 psi  (CSI = 0.18)   ➜  OK
fv = = 37.21 psi
 fv = 37.21 psi < Fvx' = 201.25 psi  (CSI = 0.18)   ➜  OK
5/19/2023 5
ΔLL =   =   = 0.10 in.
(L/d)LL = 108.00 / 0.10 = 1086
 ΔLL = 0.10 in = L/1086 < L/360   ➜  OK
ΔTL =   =   = 0.13 in.
(L/d)TL = 108.00 / 0.13 = 843
 ΔTL = 0.13 in = L/843 < L/240   ➜  OK
fc⊥ = = 76.6 psi
 fc⊥ = 76.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.14)   ➜  OK
5/19/2023 6
