Beam Design - Garage Beam Header
Grade: SP DSS
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 71.1 lbs
Dist. Selfweight: 4.37 plf
Total Weight: 72.2 lbs
Beam Design 978 Fairfield Elmhurst, IL 2023A236
5/17/2023 1
5/17/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (195.00 + 3)] x (12 in./ft.)3 = 1.93 ft3
Volumespan = N[A x L] = 1 x [16.88 x 195.00] x (12 in./ft.)3 = 1.90 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.93 = 72.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.90 = 71.1 lbs
40 plf
10 plf
ws = 4.37 plf
16.25 ft.
16.50 ft.
448.59 lbs
448.59 lbs
5/17/2023 3
fb = = 680.7 psi
 fb = 680.7 psi < Fbx' = 2070.0 psi  (CSI = 0.33)   ➜  OK
5/17/2023 4
fv* = = 34.74 psi
 fv* = 34.74 psi < Fvx' = 201.25 psi  (CSI = 0.17)   ➜  OK
fv = = 39.27 psi
 fv = 39.27 psi < Fvx' = 201.25 psi  (CSI = 0.20)   ➜  OK
5/17/2023 5
ΔLL = = 0.19 in.
(L/d)LL = 195.00 / 0.19 = 1051
 ΔLL = 0.19 in = L/1051 < L/180   ➜  OK
ΔTL = = 0.25 in.
(L/d)TL = 195.00 / 0.25 = 773
 ΔTL = 0.25 in = L/773 < L/120   ➜  OK
fc⊥ = = 99.7 psi
 fc⊥ = 99.7 psi < Fc⊥x' = 660.00 psi  (CSI = 0.15)   ➜  OK
5/17/2023 6
