Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 308 plf
Dead Load: 59.2 plf
Selfweight: 85.3 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 87.5 lbs
Beam Design 2023A232
5/17/2023 1
5/17/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (117.00 + 3)] x (12 in./ft.)3 = 2.34 ft3
Volumespan = N[A x L] = 2 x [16.88 x 117.00] x (12 in./ft.)3 = 2.29 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.34 = 87.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.29 = 85.3 lbs
308 plf
59.2 plf
ws = 8.75 plf
9.75 ft.
9.50 ft.
10.00 ft.
1879.75 lbs
1879.75 lbs
5/17/2023 3
fb = = 847.1 psi
 fb = 847.1 psi < Fbx' = 862.5 psi  (CSI = 0.98)   ➜  OK
5/17/2023 4
fv* = = 65.79 psi
 fv* = 65.79 psi < Fvx' = 201.25 psi  (CSI = 0.33)   ➜  OK
fv = = 81.46 psi
 fv = 81.46 psi < Fvx' = 201.25 psi  (CSI = 0.40)   ➜  OK
5/17/2023 5
ΔLL = = 0.13 in.
(L/d)LL = 117.00 / 0.13 = 931
 ΔLL = 0.13 in = L/931 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 117.00 / 0.15 = 763
 ΔTL = 0.15 in = L/763 < L/240   ➜  OK
fc⊥ = = 208.9 psi
 fc⊥ = 208.9 psi < Fc⊥x' = 565.00 psi  (CSI = 0.37)   ➜  OK
5/17/2023 6
