Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 308 plf
Dead Load: 59.2 plf
Selfweight: 35.1 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 36.0 lbs
Beam Design 2023A231
5/17/2023 1
5/17/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (117.00 + 3)] x (12 in./ft.)3 = 0.96 ft3
Volumespan = N[A x L] = 1 x [13.88 x 117.00] x (12 in./ft.)3 = 0.94 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.96 = 36.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.94 = 35.1 lbs
308 plf
59.2 plf
ws = 3.60 plf
9.75 ft.
9.50 ft.
10.00 ft.
1853.98 lbs
1853.98 lbs
5/17/2023 3
fb = = 2471.8 psi
 fb = 2471.8 psi > Fbx' = 920.0 psi  (CSI = 2.69)   ➜  NG
5/17/2023 4
fv* = = 164.52 psi
 fv* = 164.52 psi < Fvx' = 201.25 psi  (CSI = 0.82)   ➜  OK
fv = = 195.42 psi
 fv = 195.42 psi < Fvx' = 201.25 psi  (CSI = 0.97)   ➜  OK
5/17/2023 5
ΔLL = = 0.45 in.
(L/d)LL = 117.00 / 0.45 = 259
 ΔLL = 0.45 in = L/259 > L/360   ➜  NG
ΔTL = = 0.54 in.
(L/d)TL = 117.00 / 0.54 = 215
 ΔTL = 0.54 in = L/215 > L/240   ➜  NG
fc⊥ = = 412.0 psi
 fc⊥ = 412.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.73)   ➜  OK
5/17/2023 6
