Grade: 24F-V8 1.8E SP/SP
Size: 5 x 15.125
Design Span (L): 26.25 ft.
Clear Span: 26.00 ft.
Total Span: 26.50 ft.
Live Load: 182.25 plf
Dead Load: 540 plf
Selfweight: 1525.7 lbs
Dist. Selfweight: 58.12 plf
Total Weight: 1540.2 lbs
CV Volume Factor 0.979b - - - - -
Beam Design 2023A229
5/12/2023 1
b = 5.000 in.
d = 15.125 in.
A = 5.000 x 15.125 = 75.63 in.2
Sx = (5.000)(15.125)2/6 = 190.64 in.3
Sy = (5.000)2(15.125)/6 = 63.02 in.3
Ix = (5.000)(15.125)3/12 = 1441.70 in.4
Iy = (5.000)3(15.125)/12 = 157.55 in.4
5/12/2023 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [75.63 x (315.00 + 3)] x (12 in./ft.)3 = 41.75 ft3
Volumespan = N[A x L] = 3 x [75.63 x 315.00] x (12 in./ft.)3 = 41.36 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 41.75 = 1540.2 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 41.36 = 1525.7 lbs
Distributed Self Weight (ws) = = 58.12 plf
182.25 plf
540 plf
  ws = 58.12 plf
26.25 ft.
26.00 ft.
26.50 ft.
10339.91 lbs
10339.91 lbs
5/12/2023 3
CV = = 0.979
CV = 0.979 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.979) = 2701.3 psi
fb = = 1410.3 psi
 fb = 1410.3 psi < Fbx' = 2701.3 psi  (CSI = 0.52)   ➜  OK
5/12/2023 4
fv* = = 61.21 psi
 fv* = 61.21 psi < Fvx' = 345.00 psi  (CSI = 0.18)   ➜  OK
fv = = 67.72 psi
 fv = 67.72 psi < Fvx' = 345.00 psi  (CSI = 0.20)   ➜  OK
5/12/2023 5
ΔLL = = 0.25 in.
(L/d)LL = 315.00 / 0.25 = 1260
 ΔLL = 0.25 in = L/1260 < L/360   ➜  OK
ΔTL = = 1.07 in.
(L/d)TL = 315.00 / 1.07 = 294
 ΔTL = 1.07 in = L/294 < L/240   ➜  OK
Ab = b x lb = 5 x 3 = 15.00 in2
fc⊥ = = 229.8 psi
 fc⊥ = 229.8 psi < Fc⊥x' = 740.00 psi  (CSI = 0.31)   ➜  OK
5/12/2023 6
