Size: 2.5 x 7.5
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Live Load: 40 plf
Dead Load: 12 plf
Selfweight: 38.5 lbs
Dist. Selfweight: 4.40 plf
Total Weight: 39.6 lbs
Beam Design 2023A228
5/12/2023 1
b = 2.500 in.
d = 7.500 in.
A = 2.500 x 7.500 = 18.75 in.2
Sx = (2.500)(7.500)2/6 = 23.44 in.3
Sy = (2.500)2(7.500)/6 = 7.81 in.3
Ix = (2.500)(7.500)3/12 = 87.89 in.4
Iy = (2.500)3(7.500)/12 = 9.77 in.4
5/12/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [18.75 x (105.00 + 3)] x (12 in./ft.)3 = 1.17 ft3
Volumespan = N[A x L] = 1 x [18.75 x 105.00] x (12 in./ft.)3 = 1.14 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.17 = 39.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.14 = 38.5 lbs
Distributed Self Weight (ws) = = 4.40 plf
40 plf
12 plf
  ws = 4.40 plf
8.75 ft.
8.50 ft.
9.00 ft.
253.78 lbs
253.78 lbs
5/12/2023 3
fb = = 276.3 psi
 fb = 276.3 psi < Fbx' = 2760.0 psi  (CSI = 0.10)   ➜  OK
5/12/2023 4
fv* = = 16.92 psi
 fv* = 16.92 psi < Fvx' = 304.75 psi  (CSI = 0.06)   ➜  OK
fv = = 19.74 psi
 fv = 19.74 psi < Fvx' = 304.75 psi  (CSI = 0.06)   ➜  OK
5/12/2023 5
ΔLL = = 0.03 in.
(L/d)LL = 105.00 / 0.03 = 3149
 ΔLL = 0.03 in = L/3149 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 105.00 / 0.05 = 2233
 ΔTL = 0.05 in = L/2233 < L/240   ➜  OK
fc⊥ = = 33.8 psi
 fc⊥ = 33.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.05)   ➜  OK
5/12/2023 6
