Size: 2.5 x 9
Design Span (L): 20.05 ft.
Clear Span: 19.80 ft.
Total Span: 20.30 ft.
Selfweight: 211.5 lbs
Dist. Selfweight: 10.55 plf
Total Weight: 214.2 lbs
Beam Design 2023A227
5/11/2023 1
b = 2.500 in.
d = 9.000 in.
A = 2.500 x 9.000 = 22.50 in.2
Sx = (2.500)(9.000)2/6 = 33.75 in.3
Sy = (2.500)2(9.000)/6 = 9.38 in.3
Ix = (2.500)(9.000)3/12 = 151.88 in.4
Iy = (2.500)3(9.000)/12 = 11.72 in.4
5/11/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [22.50 x (240.60 + 3)] x (12 in./ft.)3 = 6.34 ft3
Volumespan = N[A x L] = 2 x [22.50 x 240.60] x (12 in./ft.)3 = 6.27 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.34 = 214.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.27 = 211.5 lbs
Distributed Self Weight (ws) = = 10.55 plf
  ws = 10.55 plf
20.05 ft.
19.80 ft.
20.30 ft.
1883.34 lbs
1883.34 lbs
5/11/2023 3
fb = = 1657.6 psi
 fb = 1657.6 psi < Fbx' = 2400.0 psi  (CSI = 0.69)   ➜  OK
5/11/2023 4
fv* = = 57.37 psi
 fv* = 57.37 psi < Fvx' = 265.00 psi  (CSI = 0.22)   ➜  OK
fv = = 62.00 psi
 fv = 62.00 psi < Fvx' = 265.00 psi  (CSI = 0.23)   ➜  OK
5/11/2023 5
ΔLL = = 0.67 in.
(L/d)LL = 240.60 / 0.67 = 362
 ΔLL = 0.67 in = L/362 < L/360   ➜  OK
ΔTL = = 1.23 in.
(L/d)TL = 240.60 / 1.23 = 195
 ΔTL = 1.23 in = L/195 > L/240   ➜  NG
fc⊥ = = 125.6 psi
 fc⊥ = 125.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.19)   ➜  OK
5/11/2023 6
