Size: 2.5 x 7.5
Design Span (L): 20.05 ft.
Clear Span: 19.80 ft.
Total Span: 20.30 ft.
Selfweight: 176.3 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 178.5 lbs
Beam Design 2023A226
5/11/2023 1
b = 2.500 in.
d = 7.500 in.
A = 2.500 x 7.500 = 18.75 in.2
Sx = (2.500)(7.500)2/6 = 23.44 in.3
Sy = (2.500)2(7.500)/6 = 7.81 in.3
Ix = (2.500)(7.500)3/12 = 87.89 in.4
Iy = (2.500)3(7.500)/12 = 9.77 in.4
5/11/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [18.75 x (240.60 + 3)] x (12 in./ft.)3 = 5.29 ft3
Volumespan = N[A x L] = 2 x [18.75 x 240.60] x (12 in./ft.)3 = 5.22 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.29 = 178.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.22 = 176.3 lbs
  ws = 8.79 plf
20.05 ft.
19.80 ft.
20.30 ft.
1865.49 lbs
1865.49 lbs
5/11/2023 3
fb = = 2364.3 psi
 fb = 2364.3 psi < Fbx' = 2400.0 psi  (CSI = 0.99)   ➜  OK
5/11/2023 4
fv* = = 69.11 psi
 fv* = 69.11 psi < Fvx' = 265.00 psi  (CSI = 0.26)   ➜  OK
fv = = 73.70 psi
 fv = 73.70 psi < Fvx' = 265.00 psi  (CSI = 0.28)   ➜  OK
5/11/2023 5
ΔLL = = 1.15 in.
(L/d)LL = 240.60 / 1.15 = 209
 ΔLL = 1.15 in = L/209 > L/360   ➜  NG
ΔTL = = 2.11 in.
(L/d)TL = 240.60 / 2.11 = 114
 ΔTL = 2.11 in = L/114 > L/240   ➜  NG
fc⊥ = = 124.4 psi
 fc⊥ = 124.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.19)   ➜  OK
5/11/2023 6
