Design Span (L): 11.05 ft.
Clear Span: 10.80 ft.
Total Span: 11.30 ft.
Selfweight: 57.1 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 58.4 lbs
Beam Design 2023A217
5/9/2023 1
5/9/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (132.60 + 3)] x (12 in./ft.)3 = 1.71 ft3
Volumespan = N[A x L] = 2 x [10.88 x 132.60] x (12 in./ft.)3 = 1.67 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.71 = 58.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.67 = 57.1 lbs
ws = 5.17 plf
11.05 ft.
10.80 ft.
11.30 ft.
1017.94 lbs
1017.94 lbs
5/9/2023 3
Fbx' = (900)(1.00)(1)(1)(1)(1.2)(1)(1) = 1080.0 psi
fb = = 1255.6 psi
 fb = 1255.6 psi > Fbx' = 1080.0 psi  (CSI = 1.16)   ➜  NG
5/9/2023 4
fv* = = 61.14 psi
 fv* = 61.14 psi < Fvx' = 180.00 psi  (CSI = 0.34)   ➜  OK
fv = = 68.65 psi
 fv = 68.65 psi < Fvx' = 180.00 psi  (CSI = 0.38)   ➜  OK
5/9/2023 5
ΔLL = = 0.22 in.
(L/d)LL = 132.60 / 0.22 = 603
 ΔLL = 0.22 in = L/603 < L/360   ➜  OK
ΔTL = = 0.40 in.
(L/d)TL = 132.60 / 0.40 = 334
 ΔTL = 0.40 in = L/334 < L/240   ➜  OK
fc⊥ = = 113.1 psi
 fc⊥ = 113.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.18)   ➜  OK
5/9/2023 6
