Beam Design - Irvine Project
Design Span (L): 3.25 ft.
Clear Span: 3.00 ft.
Total Span: 3.50 ft.
Live Load: 300 plf
Dead Load: 100 plf
Selfweight: 13.0 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 14.0 lbs
Beam Design Mussie Petros 1531 N St 323 Sacramento, CA 95814 Irvine
5/8/2023 1
5/8/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (39.00 + 3)] x (12 in./ft.)3 = 0.41 ft3
Volumespan = N[A x L] = 1 x [16.88 x 39.00] x (12 in./ft.)3 = 0.38 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.41 = 14.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.38 = 13.0 lbs
300 plf
ws = 4.01 plf
3.25 ft.
3.00 ft.
3.50 ft.
707.01 lbs
707.01 lbs
5/8/2023 3
fb = = 202.3 psi
 fb = 202.3 psi < Fbx' = 900.0 psi  (CSI = 0.22)   ➜  OK
5/8/2023 4
fv* = = 24.69 psi
 fv* = 24.69 psi < Fvx' = 180.00 psi  (CSI = 0.14)   ➜  OK
fv = = 58.36 psi
 fv = 58.36 psi < Fvx' = 180.00 psi  (CSI = 0.32)   ➜  OK
5/8/2023 5
ΔLL = = 0.00 in.
(L/d)LL = 39.00 / 0.00 = 14747
 ΔLL = 0.00 in = L/14747 < L/360   ➜  OK
ΔTL = = 0.00 in.
(L/d)TL = 39.00 / 0.00 = 10951
 ΔTL = 0.00 in = L/10951 < L/240   ➜  OK
fc⊥ = = 157.1 psi
 fc⊥ = 157.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.25)   ➜  OK
5/8/2023 6
