Size: 3.125 x 7.5
Design Span (L): 19.71 ft.
Clear Span: 19.42 ft.
Total Span: 20.00 ft.
Bearing (lb): 3.5 in.
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 108.3 lbs
Dist. Selfweight: 5.49 plf
Total Weight: 109.9 lbs
Beam Design 2023A214
5/5/2023 1
b = 3.125 in.
d = 7.500 in.
A = 3.125 x 7.500 = 23.44 in.2
Sx = (3.125)(7.500)2/6 = 29.30 in.3
Sy = (3.125)2(7.500)/6 = 12.21 in.3
Ix = (3.125)(7.500)3/12 = 109.86 in.4
Iy = (3.125)3(7.500)/12 = 19.07 in.4
5/5/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [23.44 x (236.50 + 3.5)] x (12 in./ft.)3 = 3.26 ft3
Volumespan = N[A x L] = 1 x [23.44 x 236.50] x (12 in./ft.)3 = 3.21 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.26 = 109.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.21 = 108.3 lbs
Distributed Self Weight (ws) = = 5.49 plf
100 lbs
75 lbs
  ws = 5.49 plf
19.71 ft.
19.42 ft.
142.45 lbs
142.45 lbs
5/5/2023 3
fb = = 462.4 psi
 fb = 462.4 psi < Fbx' = 2760.0 psi  (CSI = 0.17)   ➜  OK
5/5/2023 4
fv* = = 8.85 psi
 fv* = 8.85 psi < Fvx' = 304.75 psi  (CSI = 0.03)   ➜  OK
fv = = 9.07 psi
 fv = 9.07 psi < Fvx' = 304.75 psi  (CSI = 0.03)   ➜  OK
5/5/2023 5
ΔLL =   =   = 0.14 in.
(L/d)LL = 236.50 / 0.14 = 1697
 ΔLL = 0.14 in = L/1697 < L/360   ➜  OK
ΔTL =   =   = 0.34 in.
(L/d)TL = 236.50 / 0.34 = 699
 ΔTL = 0.34 in = L/699 < L/240   ➜  OK
Ab = b x lb = 3.125 x 3.5 = 10.94 in2
fc⊥ = = 13.0 psi
 fc⊥ = 13.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.02)   ➜  OK
5/5/2023 6
